Possibly a dumb question or a dumb person
salinasjoel
Learning Daily
Indianapolis, IN
First time having an early a as opposed to a post 67 car. I upgraded the brakes and everything is working ok. But my question is if the rear bowl on the mc should feed the front or rear brakes. If I remember correctly it should feed the fronts but I need conformation.
Thanks
In most cases the reservoir has the divider off centered. The larger area feeds the front since the calipers consume more fluid as those linings wear.
