Post your sound bytes here.
7demon2
Registered User #1824
Rockville Va.
i think i might have a great idea :!: . today it dawned on me that alot of the questions in the mopar exhaust section related to one common theme. what kind to buy, and what do they sound like? well i have watched giggy's duster video, and thought this is the kind of stuff that really helps. i think this video should be sent to the mopar exhaust section as a stick thread. anyone else that has either videos or just sound files of their set up could then post to this data bank. the posts should list engine size, compression, cam specs, headers or not, tube size( if it applies) , pipe size, type of muffler, h pipe or x or none. i think these are the only things that contribute to the sound of the exhaust sound. posts can be either a video like giggy's or a simple wave file. length should be no longer than 25-35 seconds. should include idle quality ,and a few revs of the gas. (see giggy's it is perfect) :yawinkle: what do you think........ :thumblef:
i thought about that too......but i think how ever giggy's is done is about perfect. a database like this would be awesome for reference.
I agree, it is a good idea. If you notice from mine you can really tell a difference between standing right behind it with the camera up at eye level, and then when I had it at outlet level it sounded different.
But this would be a great idea, when I was looking for mufflers I would have really loved to have heard different clips in order to choose from.
exactly right giggy.......i hate it when these muffler companies offer sound bites of stock trucks and suvs. sometimes a mustang, or camaro, or a rice burner. none of which is what we want to hear. i really like this idea, can't say it enough!!
Good idea, Im going to make this a sticky so get posting clips.
hey thanks adam! i think this is going to be great. is it possible to move this to the mopar exhaust section and bring giggys video in with it? it needs to really be there........thanks again!
I will move the thread to the exhaust section and start another for the links to sound bites.
Please post your exhaust sound bytes in this thread.
List the following info.
Engine size
Cam size
Header brand and size
Pipe diameter
Cross over - X pipe, H pipe, none
Muffler type and size
Tail pipes, size.
Engine size: 360
Cam size: 280 dur/.474 lift
Header brand and size: 340 HP Manifolds
Pipe diameter: 2 1/2"
Cross over - X pipe, H pipe, none: X-Pipe
Muffler type and size: Dynomax Superturbos
Tail pipes, size. 2 1/2"
Sound bite on site
http://www.jlpaasch.com/Updates.htm
sounds good there JLP. i was curiouse as to what the difference between the first listing is from the second? the second sounded lower and deeper.....also what is the compression you are running?
the first one is as recorded and the second was converted to 8bit stereo. CR is 9.5
Since we can't attach a .wav file to a post (Valid file extensions: bmp doc gif jpe jpeg jpg pdf png psd txt zip), any suggestions on a place that will host all these sound clips permanently??
If you missed it check out the thread "mufflers" by nasty68 (in July `05)and listen to mikelbecks post at full throttle.It`s almost intoxicating!
Most excellent..."One" for the "A" Bodies Only team :thumblef: :supz:
Next we will be able to have races on line together...Get onto it boys
Now I just got to figure out how to put it all these sound devices together :book:
7demon2 said:
hey that sounds good 69signetv8! what compression are you running?
Da...sorry. I really can't quite remember...there was nothing speical about the rebuild in this engine...so I would guess..pretty much stock would be my answer.
360
9:1 CR
455/475 cam (advertised)
Cheap headers (1 5/8 primary, 3" collectors)
Edelbrock RPM mufflers 2.5 I/O
Aluminized 2.5" pipes (welded, custom bent), H pipe
http://media.putfile.com/Dart46
This is the only video I have right now. I'll get one revving when the car is back together (In garage, getting new front suspension).
