dartman53
Have from a 68 cuda I believe it to be a 7" oem booster for drum/drum power brakes.
Rubber boot is in 2 pieces is the only thing I see wrong w/it. I was told it worked on the car then the guy put disc up front so he took it off. 100.00
Have 2 drive shafts I used in my 71 Dart Swinger
The black one was w/727 trans and 8.75 rear end,no yoke or ujoints 100.00 it has been balanced already just put on your stuff and install!
The gray one is from a 67 satelite which was set up for my Dart after I put in an a833 trans and dana 60 also bal. no yoke or ujoints should mention this has a rubber bushing where the rear yoke is mounted on the shaft. I believe it was for removing vibration, not sure.80.00
PICS uploaded
pm me for more info or pics
PICS uploaded
