71DartGuy
I recently purchased a booster and master cylinder assembly from an old a body, not sure what, and it came with the proportioning valve from the disk brake car too. My 71 dart now has manual drums. The question is, Does the prop. valve from the disk car bolt up to all the lines in the same ports? It looks as though the parts are identical, so I guess the differences are inside. I'm guessing I can just bolt up the booster, connect the push rod to the pedal, and then hook up all the lines into the new prop. valve? It seems straight forward but I dont want to miss anything. Thanks
Mike
Mike
