Power Steering Box Interchange???
dustermaniac
Senior Member
Modesto, CA
I was wondering if a power steering box from a 1976 Aspen with an 833 4 speed would interchange into a 1973 Duster with factory? V8 power steering? The box on my Duster is leaking at the return line and even though I have tried replacing the two 'O" ring seals, I cannot get the damn thing to stop leaking. At this point, I just want to change out the box and was wondering if this style box would fit? Please help if anyone out here knows, or if anyone out here has a power steering box from a 73-74 Duster with a V8 then I would be interested in purchasing it. Or where I can order these O ring replacement seals? Thanks in advance.
hello I have compared the F body power steering box to the one on my 66 valiant before and they look to be Identical but not sure if they will bolt up, the steering box for F body should be the same from 76-80 and auto and manual trans
Thanks for the info. I ordered the box and am going to see if it will match up. By the pictures of it, it looks to be the same with the same mounting holes.I will know soon.
if the one you ordered doesn't work, i have a power steering box out of a 68 barracuda and am local to you. if your interested let me know.
I'm unsure of the condition. It yours if you want it, just come get it. I know it works, I just don't know if it leaks.
