[WANTED] Power Steering complete for 69 Barracuda Slant 6
momoparman
MOISMYHOME
M I Z Z O U
Have a 1969 Barracuda vert with a slant 6 that is manual steering car.
Would like the complete setup to switch to power steering.
Pully
Pump - correct for year
Box.
Brackets.
Bolts.
Hoses or part numbers
Belt or belt part number
Do not want a played out leaking box or pump, so please consider that.
Thanks.
Momo
Pully
Box.
Brackets.
Bolts.
Thanks.
Momo
You will also need a steering column
I have a 69 valiant slant 6 with power steering that is an original but in working condition.
If you would like to trade, I can make it happen, steering Column shaft and all. It is complete but I'd much rather have manual steering.
not necessarily, you can buy a conversion coupler for that to make up the difference in length.
He's going from manual to power. The conversion coupler is made for power to manual. He's gonna need a column. He's doing the same thing I'm doing to Vixen.
apologies, i should've been more detailed. you can shorten the shaft and use a coupler (flaming river, universal, etx.)
@BergmanAutoCraft probably can hook it up with a top quality coupler and detailed instructions/kit specifically tailored to the install.
or just buy a column.
