[WANTED] Power steering pulley, federal, SB press-fit no key
Phreakish
N. Idaho
Rating - 0%
0   0   0
As in title, I need a power steering pulley. It's a federal pump, no key, press-fit (no nut at all, 3/8 threaded hole in snout, 1.06 style pump).
The one I have, the rear edge of the 'ring' used for removal/disassembly is about flush with the front edge of the pulley, and it sits to far to the rear by about ~.5".
FWIW: I have an aluminum water pump, no AC, and my alternator/waterpump/crank all line up. It's just the power steering pulley that doesn't line up, and spacing it doesn't look like a viable solution.
