[WANTED] power steering pulley
I believe the Federal PS Pump only uses a press on pulley.
I needed a press on for my Federal PS Pump and purchased one from www.marchperf.com Unfortunately, the pulley does not press on far enough. It needs to go on about another 3/16" for proper belt alignment. It has been on the car for ~7 years (about 5,000 miles) and does work, but I do get a fair amount of belt squeal (when cold and/or at higher RPMs). If I was a welder, I could probably manipulate the brackets to get the proper alignment. So for now I'm living with the belt squeal/pulley misalignment until I can find a solution.:violent1:
You could also try www.cvfracing.com
I also contacted www.bouchillonperformance.com by email to see if their BPE-9270 pulley would fit my pump. They said no, but did not give any details.
Good luck with yours!:headbang:
