Pre magnum 360 flywheel question
Mopar92
Lewisburg tn
Ended up going a different route. I'm using an LA 360 instead. I want to mate it to an 833 in the Duster. Where is a good source for these? I'm only finding magnum flywheels. The guy I bought the core engine from had one but it was pretty burned up and had been resurfaced twice. Looking for new.
I bought a flywheel from 440source.com. Theirs will work with either internal or externally balanced engines because you can remove a weight from the flywheel to make it neutral.
Rod
Don't forget, if the 360 gets different weight pistons,or different from factory rods, it will need to be rebalanced, and the 360 replacement flywheel may become unuseable.
I obtained an early 340/318 flywheel and had it balanced for my reciprocating parts.
The hypers are considerably lighter than the oem slugs. Your engine won't rev like a 5.0 Ford, but it will rev a lil quicker.
Depending on your combo, that oem flywheel is pretty heavy.I like it cuz taking off with a 10.97starter gear is a dump it-and-go deal. But really a lighter one would be ok for my combo.
