Prep for repaint after brake fluid damage
Mopar Body and Trim
  1. mbaird
    mbaird mbaird FABO Gold Member
    4,443
    1587
    Dec 10, 2005
    boise, Id
    Local Time:
    3:56 AM
    While I have my engine out I am going to repaint the driverside fenderwell that was damaged by a leaking Master cylinder.
    How should I go about cleaning prepping the surface to make sure the new paint adheres ?
  2. 4spdragtop
    4spdragtop FABO Gold Member FABO Gold Member
    25,670
    5142
    Aug 28, 2009
    Ontario
    Local Time:
    4:56 AM
    We swapped dad's cuda to dot 5 after a spill with the old style fluid.
    Sorry not much help with prep work.
  3. TrailBeast
    TrailBeast Slightly Twisted Member
    19,663
    6176
    Mar 11, 2011
    Arizona
    Local Time:
    2:56 AM
    You would go about it the same way you would any surface getting ready for paint.
    Clean it with Lacquer thinner or something similar, sand, primer, sand and paint.
    I had a fender primered sanded and ready for paint that was in my shed so nothing would get on it.
    There was a weed eater I put up in the rafters to make room for the fender and it dripped gas/oil on about a 1 foot area overnight.
    Pissed me off man. :D
    I went out in the morning to get it set up for paint and had a nice oily goo spot.
    It did turn out ok after it was finally done.
    • Like Like x 1
    • 1969moparDART
      1969moparDART Well-Known Member
      206
      29
      May 15, 2018
      texas
      Local Time:
      4:56 AM
      use b-12 carb clener and a shop rag and just scub away, be carefull about getting it on any existing good paint though because its pretty volatile stuff
      • Agree Agree x 1
      • mbaird
        4,443
        1587
        Dec 10, 2005
        boise, Id
        Local Time:
        3:56 AM
        I understood brake fluid to be more pervasive than other fluids and have some lingering effects if not treated properly.
      • TrailBeast
        19,663
        6176
        Mar 11, 2011
        Arizona
        Local Time:
        2:56 AM
        Not that I have ever seen or dealt with, as it needs to be cleaned up just as if it were oil.
        You could hit that spot with self etching primer once clean just for a little peace of mind.
      • TrailBeast
        19,663
        6176
        Mar 11, 2011
        Arizona
        Local Time:
        2:56 AM
        Yep, pretty much any good strong solvent works well for that kind of stuff.
        I like lacquer thinner because it dries up really fast, but so does the b12.
        • Agree Agree x 1
        • jos51700
          jos51700 Well-Known Member
          4,587
          1320
          May 24, 2009
          Bel-Ray
          Local Time:
          4:56 AM
          Brake cleaner the piss out of it.
        • brian6pac
          brian6pac Well-Known Member
          3,641
          2139
          Nov 15, 2016
          N.E.Ohio
          Local Time:
          5:56 AM
          Good soapy hot water will clean it good for a start, then prep it and prime it.
          Brake fluid is water soluble.
          • Like Like x 1
          • forphorty
            forphorty Well-Known Member
            586
            180
            Jan 19, 2006
            Local Time:
            4:56 AM
            TrailBeast, Do you ever get ribbed about your CobraJet scoop? :poke::)
