fishy68
Tyr Fryr's Inc.
I was building a 8-3/4 unit just for the track but other priorities dictate selling this.
489 housing hot tanked and painted "cast blast" with the pinion bearing races already installed. All the other NIB Timken bearings and pinion seal are there as well as a good set of used MP ring gear bolts (only used once in a low hp app) and a good locknut (for 10 spline pinion) and Belleville washer (same as ring gear bolts, only used once). Caps are marked and I measured the cap offset and wrote the offset factor on the case to make it easy when setting the pinion depth.
I just noticed that in the pictures the adjuster locks and bolts are not in the box. I found them and put them in it so you will get them too.
I have $160 in it and that's all I'm asking plus shipping. Located in central IL
PM me if interested
PM me if interested
