Drive45
This is a very good 1972 440 core for your next project build. It has a good forged crank in it and has never been removed. I took a cap off and the main bearing is stamped "72", same year as the block. Crank does spin free in block as well. It has some surface rust from sitting but no pitting. Very nice combo and has all main caps and rear seal retainer. A good bake and blast and it will look like new again. It is a standard bore block at 4.320" and all lifter bores are standard size, no oversized ones in this block.
Asking $750 for the pair and shipping is NOT an option. Needs to be picked up or maybe delivered if its not more than 100 miles away.
Located in Dewitt Michigan 48820
