[FOR SALE] Pro Built 318 Engine - BRAND NEW
vernair
Long Beach, CA
Rating - 0%
0   0   0
Hi everyone.
I had this professionally built for my old 1965 Plymouth Barracuda to replace the stock 273, but I ended up selling the car before putting this in.
It is BRAND NEW, 0 miles on it. It's only been broken in on the stand at the shop. I paid about $5k for it just 6 months ago. You can hear/see it run on the stand here:
PHD The Speed Center | Facebook
(Scroll down to July 2)
Here's the specs:
315 hp / 330 torque
Block is Line honed/bored and honed with torque plates to .030
New Flat top cast pistons
New Moly rings
New Clevite bearings
Reman connecting rods
Reman crankshaft machined .010/.010
Rotating assembly balanced
New Comp Cams Hyd Flat tappet camshaft and matching lifters
Custom built cylinder heads with
New valve guides
New oversize stainless steel intake valves
New stainless steel exhaust valves
New valve springs to match the cam
New viton pc valve seals
New Hard exhaust seats
Performance valve job
CBN surfaced
Speed master 1.5 ratio shaft roller rocker arms
New .080 wall push rods
Mopar Performance cast aluminum valve covers
New Aluminum intake
New Quick Fuel 600 cfm carb
Mopar elctronic ignition
New plug wires
Taylor wire looms
New spark plugs
New oil/filter
Balanced and Blueprinted
This is a perfect, ready to go, show quality, performance engine. Located in Long Beach, CA. Comes with used but in good condition motor mounts.
$3900
Thanks.
Vern
i lived in long beach for years. who built it for you? i used to work at Moto Guzzi Classics before i moved, do you know Mark?
Ha! Yeah that place is great. I've met Mark a long time ago but haven't been in there in a loooong time. The motor was built in Bakersfield, actually, by PHD Speed Center. I couldn't find anyone around LB that does mopars as well as PHD.
