Problem with Holley 4 bbl
Small Block Mopar Engine
  1. RustyRatRod
    RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
    85,550
    67389
    Jun 7, 2010
    Georgia
    Local Time:
    10:35 AM
    How?
  2. dart_68
    dart_68 Well-Known Member
    782
    581
    May 25, 2017
    Lakewood, CO
    Local Time:
    8:35 AM
    The secondaries are almost closed. I cracked them open about 1/3 of a turn on the screw.
  3. RustyRatRod
    85,550
    67389
    Jun 7, 2010
    Georgia
    Local Time:
    10:35 AM
    Good. That means it's "about right" as far as all that goes.
    • Like Like x 1
    • Bewy
      Bewy Well-Known Member
      2,084
      1358
      Jan 1, 2021
      Australia
      Local Time:
      12:35 AM
      Dart_68,
      A lot of things are not adding up.....
      Only 5" of idle vacuum, & you want it to idle at 700 rpm? I doubt that will happen.
      If the low vacuum is from a long duration cam, hard to believe that both pri & sec t/blades are almost closed, because the engine should need a lot of bypass air for it to idle. The engine gets this air from opening the t/blades further, drilling t/blades, etc.
      Do you know the cam specs & comp ratio?
      • Like Like x 1
      • Agree Agree x 1
      • RustyRatRod
        85,550
        67389
        Jun 7, 2010
        Georgia
        Local Time:
        10:35 AM
        Mine only idles at 6" with 250@.050 on a 108. It WILL idle "around" 750, but it doesn't like it. It'll stall every once in a while coming to a stop. If I idle it right up around 1000, it likes that much better and never stalls. At that idle speed, my primary t slots are BARELY larger than square and I can close the secondaries all the way down until they stick shut. I have them adjusted now so they just barely will not stick.
      • Bewy
        2,084
        1358
        Jan 1, 2021
        Australia
        Local Time:
        12:35 AM
        I wonder if the PCV [ if used] is part of the problem. Probably open at idle, admitting a lot of air, hence t/blades not reqd to be cranked open further.
      • RustyRatRod
        85,550
        67389
        Jun 7, 2010
        Georgia
        Local Time:
        10:35 AM
        Sounds like it's getting air from somewhere if closing the air screws won't kill it, doesn't it?
      • volaredon
        volaredon Well-Known Member
        1,497
        511
        Feb 28, 2010
        IL
        Local Time:
        9:35 AM
        Problem? The word "Holley" explains said problem.
        • Disagree Disagree x 1
        • dart_68
          782
          581
          May 25, 2017
          Lakewood, CO
          Local Time:
          8:35 AM
          I've replaced the current PV with a 25 (was 65). Secondary throttle blades were 2 turns out from fully seated. I set them to 1 turn for startup. Idle mixture screws set to 1 1/2 turns out for startup. Primaries set with a "square" of the transfer slot showing (picture). I've not had time to start it since I set changes back to what I believe is square 1 but I'll keep you up to date when I do.
        • RustyRatRod
          85,550
          67389
          Jun 7, 2010
          Georgia
          Local Time:
          10:35 AM
          What is the idle vacuum reading warmed up and in drive?
        • RustyRatRod
          85,550
          67389
          Jun 7, 2010
          Georgia
          Local Time:
          10:35 AM
          Nevermind. I forgot. You already said 5". The PV makes ZERO difference at idle. There is nowhere for the fuel to go if it's blown or open. The boosters have to have a signal to pull fuel into the venturis and without the throttle open, that ain't happenin. Effectively, you could throw the PV in the ditch and tune correctly for idle.....so don't get caught up worrying about the PV "right now". That said, you are at a good starting point for the PV now though.
          • Thanks! Thanks! x 1
          • Agree Agree x 1
          • RustyRatRod
            85,550
            67389
            Jun 7, 2010
            Georgia
            Local Time:
            10:35 AM
            Crap, what's the duration @.050"?
          • dart_68
            782
            581
            May 25, 2017
            Lakewood, CO
            Local Time:
            8:35 AM
            Here are the cam specs as provided by Oregon Cam Grinding.
            Cam lobe lift .359 intake .372 exhaust
            Duration @ .050 - 235/247
            Lobe separation 110
            Intake center line - 106
          • RustyRatRod
            85,550
            67389
            Jun 7, 2010
            Georgia
            Local Time:
            10:35 AM
            You got somethin WRONG. There's no way in HELL that cam is not pullin more vacuum than it is. Maybe a wrong gasket in the carburetor....internal vacuum leak or somethin.....Hell, my slant 6 pulls more idle vacuum and it has 250@.050 on a 108. Let's go the direction Bewy was.....are you running a PCV valve? If so, yank it off and plug the port where it's plugged in....and that IS in the carburetor, right?
          • dart_68
            782
            581
            May 25, 2017
            Lakewood, CO
            Local Time:
            8:35 AM
            PVC is connected to the throttle plate port on the back of the carb and gets full manifold vacuum.
          • dart_68
            782
            581
            May 25, 2017
            Lakewood, CO
            Local Time:
            8:35 AM
            As an FYI, I've looked for vacuum leaks elsewhere and can find none. No uncapped or unused ports, no leaks around the base of the carb or intake. Only place I can't look is the underside of the manifold.
          • dart_68
            782
            581
            May 25, 2017
            Lakewood, CO
            Local Time:
            8:35 AM
            It CAN idle at 700...it just doesn't like it. 850 is far more stable.
          • Daves69
            Daves69 Well-Known Member
            6,411
            5219
            Feb 20, 2011
            WestOfChi
            Local Time:
            9:35 AM
            Find someone with a known good carb you can test your Holley against?
            Lol, can't or don't want to. (Just kidding) Could you possibly be pulling air from an internal heat crossover leak?
          • dart_68
            782
            581
            May 25, 2017
            Lakewood, CO
            Local Time:
            8:35 AM
            Well, the intake is a Holley Street Dominator so there is no heat crossover passage. However, it does have an EGR mounting pad but I've checked that for leaks.
          • 448Scamp
            448Scamp Running Free
            388
            409
            Jul 4, 2021
            Sandy Utah
            Local Time:
            7:35 AM
            If it’s a STREET Dominator it has a heat crossover. If it’s a STRIP Dominator it doesn’t have the crossover.
          • dart_68
            782
            581
            May 25, 2017
            Lakewood, CO
            Local Time:
            8:35 AM
            Perhaps you're correct but the heads are Speedmasters and they don't have a heat crossover.
          • RustyRatRod
            85,550
            67389
            Jun 7, 2010
            Georgia
            Local Time:
            10:35 AM
            Can we get a list or model number? How much adjustability does the carburetor have? Air bleeds? Fuel restrictors? What exactly are we talking about in a carburetor here?
          • dart_68
            782
            581
            May 25, 2017
            Lakewood, CO
            Local Time:
            8:35 AM
            Its a 3310-2 VS 750 CFM. Air bleeds are not adjustable. Only things you can readily adjust are idle fuel mixture via the screws, main fuel mixture via standard jets and PV, secondary main metering via a plate, primary and secondary throttle blade positions, float level, and VS opening rate via a diaphragm spring.
          • RustyRatRod
            85,550
            67389
            Jun 7, 2010
            Georgia
            Local Time:
            10:35 AM
            It sounds like you need to lean out the idle circuit. Only way to do that I know of is to modify your existing metering block, or get one that has replaceable fuel restrictors.
            I guess you could do the age old trick of drilling small holes in the primary blades, but that's drastic, IMO. Plenty of folks have done it with good results.
            • DJC
              DJC Well-Known Member
              297
              176
              Sep 6, 2012
              Chilliwack, BC, Canada
              Local Time:
              7:35 AM
              So, is this a new carb, old carb, rebuilt, has it ever had proper idle screw operation?
