Proform 3310 mainbody?
Works good.
If you are swapping from a straight leg booster, the jetting is different, DAMHIK. Start where proform recommends, I believe it's pri. 72's .
Once I got it sorted out it was a good change on my 340.
I'm running 72s in the 3310, thats factory jetting, the rear plate is drilled 81.
My 340 with the straight booster liked 69-70 and had to jump to 72-73 with the proform. Forgot what I put int he rear block.
That must explain why mines running rich, doesn't look like many are useing this Proform MB for the 3310.
