Project Crusty Biscuit (65 Plymouth Valiant)
Installed:
Sorry for the dark pictures my shop lighting is terrible at this angle
Wheels came in this past Sunday but the company accidentally sent them without powder coating them. No big deal, the company was really cool about it and promptly sent me return labels for me to send the wheels back to finish them. I couldn’t help but do a mock up first!
I started building the drivers side reinforced shock mount today and thought I’d go more in-depth into how I did it for this one. It’s not step-by-step but it should give a good idea
I started out with a cardboard templete the I was able to use for both sides just by flipping it. Here’s a picture of the well worn templete after kicking it around my shop for a few days:
I got a 24”x24” sheet of 3/16” plate steel to use for some of the larger brackets on my project including these shock mounts. Here’s the basic shape cut out using the templete pictured previously:
I was able to perfect the templete after I made the first mount for the passengers side and trimmed it down to fit perfectly. The drivers side fender apron is slightly different but I couldn’t afford to trim anymore off the mount so I massaged the fender apron a little bit with a hammer to get it to fit.
Here’s the mount bent into shape and final test fitted:
Next I needed to weld on the camber adjustment brackets. I drilled out the spot welds holding them onto the original mounts and made some measurements to transfer them over. Once I figured the best placement I welded them on!
Then I drilled and filed the openings:
I was tired today and forgot to take pictures of how I made the gussets for the shock mount. I basically just got some thin cardboard and put it up to the mount and traces the edges with a dirty finger. Then I added lines with a pen to get the desired profile. Some bending is involved so I did Relief cuts where the bends needed to go before I traced them out on the steel. Here’s them attached after welding:
You can see where I had to make Relief cuts to bend the steel to match the profile.
I got home from work early today and after a short nap I thought I would get started on the custom upper control arms for my car.
I just have everything tacked together for now. I ran out of gas for my welder and I am DEFINITELY not allowing oxidized welds on my suspension parts
I worked on reinforcing the other control arm today; pissed me off because I got some weld slag on the ball joint threads and boogered them up a bit. I tried cleaning them up with a file and got frustrated; anyway, here’s a pic after welding and before grinding:
