Project Crusty Biscuit (65 Plymouth Valiant)
I always seem to get lost in what im working on so there’s always gaps in the pictures of my operation sequence...
here’s a bump stop mocked up on the complete mount:
I was hoping to get the rear wheel tubs put back in today but I’m wiped. I usually try to take it easy on sundays anyway just to be rested for work the next day. I at least had to test fit the rear seat real quick though:
Now that's an ambitious undertaking looking good . One of a kind .
Are you going to use plastic air lines or metal ?
Ya might want to tie the bag brackets together to keep the "frame" rails from twisting .
Yes, I will be re-skinning the floor and they will be tied together by the floor sheet metal. And the wheel wells will add some strength across once they are reinstalled
Started working on getting my wheel tubs put back in today. Scraping the old undercoat off the old well:
I got some 18 gauge to make the rest of the wheel tubs out of, im spot welding it straight to the inside of the quarter panel so I had to contour it to the panel:
Test fitted in the car and it fits soooo good!
I guess FABO was down last night... I had a short day at work yesterday and took advantage of the extra time to get my wheel wells done. I was able to take more pictures for the drivers side since I had it all figured out:
Test fitting the sheet metal; inner wheel well is clamped in place. In used a compass to draw the contour line against the quarter panel.
Cutting along the line I drew giving enough space for a 1/2” flange
Clamped around wheel well for shape while I hammer the flange.
Tipped the edge slightly to make the bend more accurate while I hammer it
Hammer and Dooley action to shrink the metal on the edge
Final product
Coming along nicely .
What fuel pump location in or out of the tank ? If I recall Tanks inc has an in tank stock type tank for the A bodies .
Because the stock filler is too low , fuel sloshes out on hard right turns with anything over 12 gallons in the tank and the thing is a pain to fill with those vapor recovery nozzles .
I've been kicking around the idea of a Mustang tank with the filler moved from the rear to the top center and of course an in tank EFI pump . Down side one has to open the trunk to fill , and loose the spare tire well .
An other option use the spacer I got from another member here and use the Charger flip cap I have . But that doesn't solve the pain filling .
So you say why don't I move the filler higher on the fender ?
I should have before the car got painted .
You still have that option and while your at it make the fill pipe have a downward angle .
Ran out of welding gas (I think I have a leak:/...) so I did a bunch of little big things today since it was my day off.
Installed air struts on my hood. I got this set up idea from another member on here but I cannot remember who to give credit:
Continuing with the fender repairs, I applies some por15 behind the brace and where it attaches to the fender (no pic) but everything went back together nicely.
Didn’t do very much during the day today. I like,to use Sunday’s to relax, do grocery shopping, and refresh for the upcoming work week. I sat around and watched YouTube for most of the afternoon. I really enjoy some of the channels that focus on fabrications anyway, at about 9PM I was caught up and didn’t have anything better to do and didn’t feel like going to bed so I thought I would putz around and work on the new floor skin for the rear floor hump. This is what I managed bending some 18Ga over some 2” solid square bar and the edge of my work bench. I unfortunately don’t have a sheet metal brake which would have made this process much easier...
I still need to cut out and make the piece for the tunnel so I’ll work on that tomorrow.
I continued working to the rear axle hump today. First I got it to fit really well, did some trimming and sanding to smooth out the edges, and welded it in!
