PST steering boxes
Any update on the tight PST boxes? Any recent purchases with similar issues? Did the boxes loosen up? Thanks
After re-adjust working good now. About 500 miles. 215/70/14 up front if that helps at all....swingn’
Having to re-work a new steering box has to be at the least annoying. I am going to buy a new box soon but I don’t want to put the box in and then have to take it back out to re-adjust it.
Any adjustments that may be needed are the same as the factory all can be done within the vehicle without the need of removal.
Dragster, sorry I missed your post. Yes, as the pst folks said you can adjust in the car with out removing the unit. There is a specific order outlined in the fsm you would need to follow. If all goes well you shouldn’t need to. Swingn’
