Pst suspension parts exchange needed?
snapetwo
colorado springs, co
So I swapped my 73 k member, s6 w disc brakes for a 71 k, v8 w drum.
Only thing I see needing changed is the idler arm. The rest of parts arent bolted to k member.
Contacted Pst and was informed now my ball joints both upper and lower will not work now.
Can anyone tell me why?
From what I see, I don't see any issues...
Keep in mind, all I swapped was the k. Car is still disc.
If I went to drum, I could see needing ball joints.
My 'Cuda is not of that vintage, but I seem to recall reading that the location of the steering linkage or sway bar changed location. I can't remember. Somebody with more knowledge will certainly soon figure it out for you.
If your car was a 9'' drum brake /6 they may be thinking that you are going to disc brake spindles that require the bigger ball joints. Just a thought...
If all you changed was the K frame and your still using the disc brake control arms and spindles your ball joints are fine.
