[WANTED] Pulley set with power steering, non-ac, early small block/LA
dart65
Los Angeles CA
Hello,
I am looking for a factory pulley set for a 1965 273 with power-steering, non-ac, driver side water pump outlet w/ bolt on timing tab. I believe it would be a 2-groove crank pulley + a water pump pulley and alternator mount?... I am converting from ac to non ac. I am only looking for the pulley set thank you.
I have an alternator mount, but, I believe it's the same one with or without A/C.
Thank you; I have the alternator mount itself but not the 65 correct "adjusting bracket" outlined in red below. The correct adjusting slide bracket would be nice, but it is the pulley set I am most interested in.
