pulleys rubbing
tcgrump
New Member
so cal
Hi guys,
Motor is 451 stroker B block. Problem is wp pulley and crank pulley are rubbing. What is the best way to correct this. Need to remove about 1/16 inch (.060) more or less from wp pulley diameter. Has anyone else been able to solve this problem. Car is nearly complete (69 Barracuda) and now this- grrrr.
Thanks a fishload!
sounds like one or the other pulleys is wrong in saying that any machine shop should be able to run either up in a lathe and remove a small amount. maybe from both would be better less material to remove that way also would depend on where the belts sit in the pulleys wouldn't want them to be out past the outer edge (sitting proud of the outer edge)
