cptmoney
Member
So the '74 Duster I'm working on has NO ignition switch left. What was once there is now a mangled mess, complete with the screwdriver in place and everything.
I was thinking of installing a push-button type starter switch and just mount it on the dash - what do you think? Would I wire this just like I do when I'm using my remote starter switch? One lead to the top of the solenoid, the other lead to the bottom? Or would that fry my starter solenoid?
And then there's the issue of how to turn it off.....yeah - just thought of that.
What would you suggest?
I'm just aiming to get the car up and running. Likely headed out as just a drag car - so it doesn't need to be anything factory correct or anything - although that might be the fastest/easiest way to manage it.
Any ideas?
Any ideas?
