Push Rods w/Oil Holes - 360 LA
pntastar69
Gilbertsville, PA
I'm ready to order specific length push rods for a 360 LA, using Comp Cams Pro Roller Rockers, Comp Cams XE268 hydraulic flat tappet. Seems to be a limited selection of ball end push rods for a 360 LA, the majority of them have oil holes. Since it oils from the rocker shafts, would it hurt to use the push rods w/oil holes in them?
I think you are OK with the oil holed push rods, since there is no oil going thru them I the first place. The push rod is hollow anyway, the only difference is the ball end had the orifices hole.
This is the manufacturing shop that makes them for most of the big aftermarket sites. Ask nice & he will throw in a spare one or two. Never know when you might need them. :)
Read his first post. Ball on both ends. Their will be no cup.
If you don't have oil holes in your lifters it wouldn't matter, but unfortunately most aftermarket lifters have these holes.
The cup's in the rocker if not on the top of the pushrod
SBM have abig angle lifter to pushrod
not a straight push on the rocker
a little extra oil to the rocker cup helps
