I can’t say for sure but IIRC T/A offset is .550 and W2 offset is .825 or close to it.
A short video that covers some of the mods. Ports were roughed in here, I did a lot of work after the video.
Very interesting. I wonder if you did not go too crazy with the port width if you could use a RPM airgap? Also is there any reason you have to cut the rocker pads down? Didn't they make W2's with traditional pads as an "econo" casting? Did those use different rockers?
