Those type camshafts are always the butt of forum jokes by all the gurus, but the fact is they work quite well.Agreed, I have a whiplash 440 cam in another motor, I am very happy with it.
I would say very close to 1 compression point.The question from above remains though. What increase of compression could be expected by changing from open chamber heads to closed chamber? Also, I agree the aluminum aftermarket heads would be ideal, or tear the short block apart for better pistons. If using the 516s, new valves, surface, hardened seats, etc it doesn't seem like a cost effective way to go nowadays. Milling the heads was quoted at $150. Yes 0.0123" taken off the intake side for every 0.010" taken at the flame face. The heads are 452, valves are good and they are factory with hardened seats. Seems like the way to go in this situation.
So they would be approximately equal to taking 0.060" off the 452s? If so, wouldn't the better flow and the already existing hardened seat be the way to likely proceed?I would say very close to 1 compression point.
It depends. If you somehow plan on taking advantage of the quench the closed chamber head can give, then no, IMO, the 452s would not do it. If your plan is to leave the pistons in the hole at TDC, then the 452s would be the better choice.So they would be approximately equal to taking 0.060" off the 452s? If so, wouldn't the better flow and the already existing hardened seat be the way to likely proceed?
I do appreciate all the info. Just asking questions before the work gets done.
I would say for now the pistons will remain as is, which is about a mile down the hole. Someday something better, just trying to get it together and finish building the car. Then works new build bugs and maybe build something better.It depends. If you somehow plan on taking advantage of the quench the closed chamber head can give, then no, IMO, the 452s would not do it. If your plan is to leave the pistons in the hole at TDC, then the 452s would be the better choice.
Then I would use the 452s.I would say for now the pistons will remain as is, which is about a mile down the hole. Someday something better, just trying to get it together and finish building the car. Then works new build bugs and maybe build something better.
.0055 is about a cc, you'd be milling a long time to get any sort of gain with a 452, last time I cc'd one it was 90 cc's. I took .080 off of my trickflows and the pushrod with my new head gaskets are at maximum length for my rockers.Ok Rob you have my attention. So, on a standard big block, when changing from, lets say 452 head and using a 516 head about how much compression would it increase? Other brands going from open chamber to closed chamber it is a drastic increase in compression. It appears through reading, the change alone nets maybe a 1/2 point or less, then the ports are not as good also, not to mention smaller valves and no hardened seats. So, decking the 516 heads, changing the valves, installing seats, etc would no longer be cost effective, or am I misinformed?
Don't make me pull the toilet card.RRR,
Post #13. I have measured the plunger travel on a great many hyd lifters & it is exactly what I said it was. I milled a set of BB heads 0.120" & was able to use stock lifters, stock pushrods & stock rockers with a shim steel h/gasket & all worked without issue. If the lifters have been used, then they need to be compressed to get an accurate idea of how much adjustment they have.
