A 1978 Super Six engine was put into my 1967. the 67 has mechanical ignition and the 78 has electronic. What do I need to get to make the switch over to electronic. I have the distributor from the 1978, thanks
Thanks man.. now do I need the electronic voltage regulator,( the 67 is the black box mechanical) and plug too and do I need to switch the ballast resistor , mine is a 2 wire and I've seen 4 wire on some ?
