Has anyone done this? Do I need anything special as far as motor mounts and tranny mounts are considered? Any problems or anything I should be aware of?
oil pan and pickup tube needs to be for a car. Carb intake of your choice. If you are going to use a mechanical fuel pump, you will have to see if the eccentric is there. It was on my '89 TBI 360. that should be about it. Oh, you might have to plug the exhaust "bleed off" holes under the exhaust ports. Your 318 will have the roller cam which is great with todays oils.
