QA1 k member
318fish
Active Member
Pell city al
Is anyone using a qa1 tube k member on a 67-69 barracuda? Does your gear box sit crooked? I dont remember my factory v8 k frame positioning it like this.
Subscribed. I'd like to know too, as I am planning on going this route when I get my taxes back in Jan.
I am not satisfied with qa1, dont waste ur money, u see the steering alignment issue, and the idler arm bracket is about 3/8in to big. Leaving you to stack washers or shims to take up the space. Oh and the shim must go on the bottom, or the inner left side tie rod will hit the tortion bar
Per Peter in the other thread you posted the steering box alignment issue in, the Borgeson isn't supposed to sit straight...
Sterering box is not supposed to be straight. Its a by product of the narrower design of the newer box. The slight angle is not an issue for the my coupler.
The other thread
QA1 install.
