qa1 lower control arms+hotckis sway bar
Spanishgold76
Active Member
Guelph
thinking of using this combination just curious if any body has run it on a 73 and later set up
I was wondering the same thing. I've got the TVS kit all the way around and was looking at the QA1 K-member ad the QA1 lowers to go with my hotchkis stuff. I just got off the phone with QA1 and with Hotchkis to check, QA1 said as long as the Hotchkis bars mount like the 73-76 factory one there shouldn't be any problems, and Hotchkis said there's mount exactly like the factory ones. So in theory it should all work together just fine. I guess ill be finding out when im don't installing everything this winter.
this is good to know thank you for spreading the wealth greatly helps with some decisions i have coming up
I know it works now. Just make sure you put the load on the suspension(either on the ground or using a jack with the front end off the ground) and it works like a charm. Just got mine out of the alignment shop on Monday and everything handles great.
Take those big chrome strips off and it'll look even better.
Oops, there goes my opinion again. :D
It's still nice though.
