[SOLD] QA1 stuff
Sedanman
67-9 Valiant specialist
chicago Il
I have a used pair of QA1 upper A arms and QA1 TS501 adjustable shocks for sale. They’re scratched up a little bit and someone was pretty sloppy with undercoating. I managed to get most off. $450 shipped
I will partial trade for 71-2 satellite stuff. Whatcha got? I need a nice speedo assy
What's the part number on the control arms? 52301 is large ball joint (73+), 52303 is small (72 and earlier).
Where is the number located? They did come off of a 66 drum brake car but with everyone swapping stuff I'm not sure if they were the later spindles or not.
Check this link for measurements of the ball jionts (small vs big). How to tell '73-up UCAs?
If you look at the pics in the link above it appears that the small ball joint (where it fits into the spindle is 0.55" thick vs the large ball joint which is aprox 0.62"thick. So if you had a caliper you could measure the thickness of the ball joint (area that fits into spindle).
