Quality control??
Newbomb Turk
In The Clouds
The top picture is a pin hole that opened up when I charged the cooling system.
Brand new intake manifold.
The bottom picture is my fix.
I was going to pull the intake and run it up on the hill so @MOPARMAGA could TIG it.
Then I said screw that and fixed it with a plug.
Just crap **** any more. It cost me at least two hours to unscrew that.
Holley can suck it.
How bout you put a vacuum gauge it there. Be the first on your block! Maybe patent the idea and sell it back to Holley?
I was wondering how it happened by charging the cooling system. Gonna havta settle for an auxillary water temp.
Porosity when pored. Is there any in the intake somewhere else external or internal? Steve pressure test all new parts for this reason.
I didn’t see any more defects. It’s got 25 minutes in the cam. I’m about to go out and drop in the inner springs and do another 20 minutes or so.
The weird thing is I looked the manifold over many times while porting it and I didn’t see anything that caught my eye.
Sadly, at this point I’m going to have to pressure test everything.
And that is just the way it is.
The cooling system on the dyno isn’t even pressurized.
Once the water level got above the manifold it started sprinkling.
Like a dumbass I thought the hose was leaking.
The beech of it is the time and aggravation. Anyone else would have had to pull it, contact Holley or the distributor, fight, ship, wait, reinstall and start over. If there was a replacement plus parts and labor they would titen the ship.
Holley can suck it.
That's how it's done when your brain works
I would keep a close eye on the spot and repair. More often than not in my experience, the cavity can go other places as well after more heat cycles. Hopefully no coolant makes it to an intake port
OR it may even have a minute crack or cracks that cannot be seen. You make a great point. We're just gettin fleeced comin and goin with the quality of auto parts.
What intake? Is Speedmaster looking better and better all the time?
The manifold is a brand new Weiand tunnel ram. It was from the last batch that Holley made and supposedly they won’t make any more.
And, Holley says they used the exact molds that Weiand did years ago. I’m not sure I buy that now. But I did when I got it.
I don’t know how many manifolds of every brand I can think that I installed and never saw this before.
It’s like @Oldmanmopar said above. His kid is pressure testing everything.
That’s where I’m at. Another detail that must be verified.
If this was a customer engine on the dyno I’d be losing my entire *** and probably both legs on this time burglar.
Edit: if Speedmaster made a tunnel ram I’d look at it.
I installed a Weiand dual plane on a BBC to find out that the temperature sending unit boss was faulty some years ago. Casting was very thin, to say the least...
