Beer keg intake
Valvebounce
Christchurch New Zealand
My apologies if this has been thrashed out before.
I should preface this by saying vehicles equipped with these manifolds were never sold new in my corner of the world. So I've never set eyes on one IRL.
Recovering from a surgery, I've spent far to long watching you tube videos, and reading how-to tutorials.
Out of curiosity I watched a couple about this intake. (Freiburger mentioned one a video I watched, which drew me down that rabbithole)
One chap on you tube posted a great video showing all the nooks and crannies in great detail.
Maybe it was the pain killers, but what leapt out at me watching that video was, how easy it would be to strap on the the mill, and machine the top out of it.
Then make a mating flange, and TIG weld it to the open hole you'd made in the top.
Then it would be a breeze to attach something like this- https://www.aliexpress.com/item/1005006330443848.html on top,
Depending on what the junkyard stock is like where you are, a used one might be cheaper.
Since the manifold already has provision for injectors, it's a short leap to run efi.
And since the milling out would remove where the intake runners cross over, it's not a stretch to put in a false floor/blanking plate which would both reduce plenum volume, and plug off the redundant halves of the runners.
I'd sorta assumed that these would be worth nothing? But the only ones I saw for sale, the sellers were asking g more than you'd pay for a semi decent 4nnl manifold.
/go figure......
One problem with blowing one of those is the valley cover which is the manifold bottom. Even with atmospheric intake, these have been known to crack and fail from the vibrations of the intake pulses. You would want to fabricate and build a heavier one, weld it in.
Also I hope you know these are magnum bolt pattern, you cannot use them on LA heads
That would be one taaaall intake setup...
And a lotta fabbin' for the drive. Much easier to just slap a turbo or two on it after putting the improved Hughes bottom plate on it.
https://hughesengines.com/Index/pro...U21hbGwgQmxvY2sgRG9kZ2UgTWFnbnVt&partid=30712
Not sure what you'd do for a throttle body that has compatible connectors and sensors for the JTEC controller, and you're sure not going to be able to run a carb on it either.
But anything can be done if you're persistent enough.
@MonkeyMadness did something similar.
20160812_101206-jpg.1714958645
20161003_184658-jpg.1714976637
20190316_182117-jpg.1715304707
20191228_172454-jpg.1715444979
:rofl: Ha! this is soo funny and odd :realcrazy:, that this topic and I was brought up... lol As I am in the pulmonary stages of sourcing parts to do this again just this time on a gen3 hemi...:poke:
/go figure......
As for @Valvebounce DO IT! fcuk wat everybody says good or bad it only "can't be done" if you don't even try! DO IT!
These manifold are easy to get and so are roots style blowers! The Magnum/LA block is robust enough for boost. Screw it pop a few head gaskets have fun with it! Isn't that what all this is about... Hit me up if you need anything!
Guess I was picturing something completely different- just the very top of the beer keg cut off and the blower mounted way up top.
Seeing the way MonkeyMadness did it clarifies things a lot- that looks awesome! :thumbsup:
