Question, 3 2 barrel throttle bodies on V8
spl440
Everybody's Fool
Hot Springs AR
would it be possible to use 3, 2 barrel throttle bodies being driven by a v6 multi point computer on a V8? I would see if it could be reflashed so would act like a 6 pack set up with center 2 as primary then progressive secondary's. And yes, only using it to for the fuel, not the ign.
From my readings for Megasquirt, usually the injector drivers used in computers can only drive 2x "TBI" style injectors since they have a different impedance than MPFI style. The other thing with EFI is that you'd not want progressive linkage on a TBI setup. It's actually OK on a "dry flow" 4bbl throttle body with port injectors, but otherwise, they should be 1:1.
If you want EFI for any reason other than better cold starting and drive-ability, I'd jump directly to a multi-port setup.
Six Pack EFI? On my wish list! :thumbsup:
F&B Throttle Bodies - Fuel Injection components and 6pack EFI for Magnum engines, 4.7 engines, Vipers, 4.0 Jeeps, and the Hemi
thanks for all the replies, was just thinking outside the box as usual.......and am just looking for better cold start and drivability.
