I am reassembling my A833 non-OD. Should the rear bearing that goes into the tailshaft be pressed up against first gear or pressed on just enough to get the snap ring on the shaft? I am assuming it does press all the way up to first gear so the gears are tightly meshed, but need to be sure.
