Question about what diff's
MarzGraphixDesign
South Cack-alacky
Hey yall, I have a question about a 65 fury III 4dr, It has a 318 poly. I found the car at the local you pull it yard. I've been looking for a 8,3/4 for a 87 D150 short bed. First would the Fury 3 have a 8.750. and what kind of bolt pattern would it be. Thanks.
5 lug 4 1/2" bolt circle. You will have to move the spring perches. On a car the springs are under the rear. On a truck they are on top.
Thanks for the spotter guide. I always have a problem with the 9.25 and the 60. It's like get this brain lock and can't remember. The 5 on 4.5 will be better then the 5 on 5 I have now. I figured as much for moving a few things around.
Here is another one
You should contact member "blu340dart", he has an 8 3/4 out of a truck he would like to sell!!
