question on mounting power disk brake booster on 65 cuda
mkingan
arkansas
so i got a kit to convert the front of my 65 cuda to power disk brakes. the one thing i am confused it no matter what i tried the booster and bracket for the shaft that pushes in was hitting the firewall. i called pirate jack where i got the kit and explain. He said oh you have to cut the rod all the way back to the boot to get the clearance. Really? little nervous doing that cause if i mess it up don't know if i can replace that. suggestions? comments?
so mine is this kit the rod is adjustable but according to them that rod on the booster needs cut back to the boot to function correctly and have clearance
