I have read a few articles that talk about adding a small dab of silicone around the water ports before installing head gaskets. Does anyone do this? I've always thought that the newer gaskets just go on dry. Does anyone use any other type of spray or sealant to help the head gaskets seal? It just seems to me that when I pull apart an engine that hasn't had the heads off before that there is a fair amount of gasket material stuck to the surfaces. But when I pull apart an engine that has had the heads off the gaskets don't seem to have adhered themselves to the block or heads as well.
