Dragonbat13
I am wanting to get a set of the Indy MAX, Magnum type heads with hydraulic roller beehive springs from Brian at IMM. The special he advertises. I want them because they seem to be a good deal and they can support upgrades in the future.
But with all the other stuff going on I really cant afford a top end along with a stroker build (future upgrade, but way down the road). So what I plan is a basic rebuild on a magnum 360, if necessary and install the heads along with a magnum specific performer RPM intake, holley vac secondary carb, TTI Step headers, custom grind cam and custom torque convertor. The rest of the car is listed in my sig.
I am somewhat concerned about the heads being too big for the 3.23 gears.
Will the heads be too big and kill low end?
Also, can the MAX heads be drilled to accept both styles of intakes?
