mean318
Hey everyone, I have taken out my 742 4.11's out of the car again because of all the noise it was making. I narrowed it down to the pinion having end play, which all I could think of is that the bearing races were not in all the way. I have now beat on the races and visually inspected that they are all the way in. The problem I am having is that I have no bearing pre-load unless I put in a pretty think shim in between the gear and bearing which in turn would change the pinion depth. I have no shims on the yoke side because after reading the mopar muscle tech article on 8 3/4's it says to loosen bearing pre-load you add shims to the yoke side of the shaft. So what should I do?! Do I set the pre load first and then go to pinion depth? What I saw before I took it all apart the first time was that the gear pattern was "walking" I am thinking that was from the loose pinion bearing. So ladies and gentlemen what should I do? I realize I have probably answered my own questions and I would just like some input on this Thank you very much for your time and knowledge!
Sorry for the ranting
