Quick 8.8 narrowing?
When digging around the junkyard, check the tag on the rear end. It will note the gears. Also look for the “L” for locker. Like “3L73” for example. That’s 3.73 gears with “posi”. “3 73” will be a peg leg.
I've built hundreds of narrowed 8.8 rears, in my opinion the best housing core for a muscle car is the Crown Vic. It uses medium thickness 3" dia axle tubes, so overall much lighter than the Explorer/F150 housings. Center casting is also lighter, and you don't have to cut off the ugly Explorer abs sensor "guards". Good compromise of strength vs weight. The CV disc brakes are also much lighter than the Explorer disc brakes. Mustang 8.8 housings are lighter yet, but they use small 2-3/4" dia thin wall axle tubes, which are very easy to bend.
FYI the 31spl Explorer bearing journals are larger than a 9" axle in that area, which means an 8.8 axle can be turned down to accept 9" bearings directly. Turns it into a 9" style axle, eliminates the need for c-clip eliminators. Just install 9" ends on the 8.8 housing and use modified 8.8 axles with 9" bearings installed. Torino style billet 9" housing ends from Dutchman Machine are around $100/pr.
If you want to build an even narrower 8.8 using stock parts, the Ranger housing has short/long axle tubes much like an Explorer. 56-1/2" AF/AF using two short side Explorer axles, 53-1/4" AF/AF using two short side Ranger axles. Ranger 8.8 center castings look like the Explorer/F150, but the Ranger axle tubes are large Explorer sized where they plug into the center housing, but the outer ends are small to take the Mustang/Crown Vic sized 1.40" axle bearings. 31 spline axle Rangers do exist, but most common is the 28 spline. Both Explorer and Ranger are 5 on 4-1/2" lug patterns.
Grant
@weedburner do you normally weld around the tube where it inserts into the center section? I think they are pressed in.
A down and dirty initial junkyard check is to use the door tag. Then verify on the diff. I usually do this the day before a 1/2 sale at the yard. For example, my 3:73 traction lock is code D4. The ranger station has mucho info on all the various specs and models. Ford 7.5 & 8.8 Inch Axle Tag & Door Codes
That's what I did when I found mine
Well found a local racer to narrow it. He actually got tube out and cut it so there is no weld in the middle of the tube. Also he tig welded the tubes back to the housing. I got new Moser aluminum cover with girdles. Also got a sweet 1350 chrome moly strange engineering yoke..time to clean it up and paint.
Hi All
When you use the Explorer rear and do the 2 short axle mod, what is the finished length to the wheel mount surfaces?
