Quick question on pitman arm installing on new borgeson box
EvanS
Alta Loma, CA
Real quick question and cant find the answer quickly, so I'm hoping someone can help.
Installing a brand new pitman arm on my brand new borgeson steering box. Nothing is marked, so should I assume that the box is centered when installing it?
I am trying to install everything on the kframe then bolt it up so, the steering column is not connected. I would rather install this now, but I guess I can wait until its in the car to install.
Any advice on the way to properly install this would be appreciated.
TIA
I read that post and it helped a little, but I'm hoping to install the pitman arm without installing the steering column.
Just turn the input shaft of the box just as if the column was attached, the process remains the same.
