I'm mocking up a Jerico behind a small block for my drag car project. I'm trying to use a Quick Time bell designed for the Jerico to SBM. I cannot get the clutch fork in the side hole when the pivot bracket is installed. (A-body clutch fork, w/ A-body Quick Time bracket) I searched and saw other threads that mentioned the hole was on the small side but has anyone successfully installed the fork from outside the bellhousing. Or is this something that needs to be done fed from the inside with the transmission out? Is there another fork option?
Thanks
Thanks
