R3 48 9.6Deck Roller
AUSA66
Perth
After a set of solid Roller lifters for R3 48 degree block Crower dont make them anymore said to use the below & flip them around not sure if the link bar centre or bore spacing is the same
has anyone tried this or recommend another Lifter
Part Number: 66234X903H-16
Severe-Duty Mechanical Roller Lifters
1174X1-16 Chrysler 318-340-360 Ultra Pro Pushrod Oiling
I have a ser of this company's lifters in my ritter block only ones that fit. But I removed the extra bolt holes valley side. Can ask them if they will work for yours. Thought I hot the higher end ones but got the little cheaper ones.
I thought the R3 needed a longer lifter so the link bars would clear the block
The block is getting bushed.
Never used Solids before so it is a new learning curve.
Well the ones I have are designed for aftermarket blocks. Give them a call I know your on the other side of the world but great people to deal with.
