radator and oil cooler help ? which ones
1994rm250
PortWashington , NewYork
hey guys i got a 76 duster got a 383 and 727 going in what radator do i use ? ?can i use my superslant sixrad ? for a bit ? and the tranyy cooler / ? thanks angelo
All of the ones he has that are around 18 x27 will work just make sure you get the inlet and outlets on the correct sides for your app or change waterpump housing.
I bought a 3 core radiator for a 1976 dodge 1 ton with a 440 engine. With slight griding to the support brackets on the rad, it slipped into my 1971 demon with a 440 six pack. Used the water pump housing from 440 source with the inlet on the passenger side and hoses from the local parts store. Looks as if it was a factory install. Works great too as the fan assembly was taken from a 3/4 ton 318 pickup truck. Hope this helps
kenny b
i use a truck housing and a universal Griffin alum radiator ($170 at summit) . Just measure your car and go from there-=--you can make anything work...
