David Dickerson
Stickler
18X26" brass/copper radiator with custom aluminum shroud. Was installed on 1974 Duster, though required modified mount holes due to larger size. 2 core radiator, suitable for stock Abody small block application. Purchased at Autozone $245 Shroud kit from Summit $60 and I did the fabrication. Used for one month while I waited for a Wizard aluminum to be built. $140, and you pay the ride. PayPal only. NY, 12122
