Thank You!If not running a shroud, the fan should be within about 1"-2" from the radiator core for maximum efficiency.
If you do use a shroud, about half of the width of the fan blades should be inside the opening of the shroud.......
Thanks!I have been told that with a shroud, the fan can be 3/4" from the radiator. and have 3/4" to 1" clearance fan to shroud
Been running a 7 blade fan and clutch on this for 3 years, the hottest it has been is 200 ona 95 degree day in traffic.
Good Luck
