Radiator for 360 in a 67 Barracuda
cudajim
cudajim
Grass Valley, Ca.
I need to know where to purchase a radiator for a 67 Barracuda that is setup for a 360 motor and automatic trans. I'd like it to fit without modifying the car and the outlet has to be on the passenger side. It would also be nice if it didn't break the bank. Thanks.
There are many posts on this, with many solutions. Most spent >$200 on an aluminum radiator. I got a radiator for a ~72 Dart at Autozone ($200), w/ lower tube on passenger side, which matches my later alum water pump. Might have been for a slant since 1.5" lower tube. I used a rubber bushing there to match my 1.75" hose. You also need to consider where the upper tube is, if you have an AC compressor. All upper tubes are 1.5"D that I have seen (most cars & trucks).
I went with be cool alum rad bolts right up and I believe Chev part # gives you same dia mention rad with lower rad hose on oppisite side!
Alright, so the Champion radiator looks ok but I have a few questions.
Will it mount with the original mounting bolt holes?
Can I or should I use my original fan shroud?
What size is original to 67 Barracuda/273 engine? (I'm not at home now).
Should I order 2 core or 3 core for a 360?
alright, so the champion radiator looks ok but i have a few questions.
Can i or should i use my original fan shroud?
What size is original to 67 barracuda/273 engine? (i'm not at home now).
Should i order 2 core or 3 core for a 360?
Didn't a 273 have a two core but the tubes were pretty wide if I recall correctly?
