Radiator help......
Heating / Cooling / AC
  1. Velocity111
    Velocity111 FABO Gold Member FABO Gold Member
    111
    22
    Jan 16, 2017
    New York
    Local Time:
    10:30 PM
    this one is for those who are good with diagnosing issues with little info..lol
    I’m working through an over heating issue, and we’ve address what we think it part of the problem. The other part is pictured here. Looking into the top of the radiator down the fill tube, you can see all these white granular things. At first I thought they were small stones, but after flushing the radiator, realized they were not. I still don’t know what it is, but it’s granular, white, and will separate when rolled or pinched in between your fingers - best description I have is it looked like wet dishwashing detergent. We are guessing it’s cutting down 10-15% of the radiators flow.
    Does anyone know what this is, and even after the motor break That was done before motor install, could this still have come from the motor? - or other? Thanks in advance...from stumped...lol
  2. Dana67Dart
    Dana67Dart Like a fine wine, only getting better with age! FABO Gold Member
    4,348
    2649
    Jul 16, 2017
    Northern Colorado
    Local Time:
    8:30 PM
    What year?
    What engine?
    What car?
    What mods?
    Electric or mechanical fan?
    OEM fan shroud?
    As for the particulate, could be calcium scale from inside the block, could be some form if stops leak.
    Not a joke, what does it taste like?
    Also IMHO if 10 to 15% blockage is causing over heating you have other issues more serious
  3. George Jets
    George Jets 1967 Dart 2 Door FABO Gold Member
    2,135
    3139
    Jan 18, 2019
    Farmington MN
    Local Time:
    9:30 PM
    Not sure what that is stuck in your radiator. Possibly a Vinegar Flush on your radiator and cooling system will break that stuff down so you can drain it out.
    Look up on Google: How to flush your cooling system with vinegar. So you can learn how to properly do it.
    Don't use vinegar with aluminum radiators and aluminum heads.
    Can take the radiator out and turn it upside down and back flush it.
    Then turn it right side up, put the garden hose in the top, the water should flow out the bottom exit just as fast as it is going in the top . . for a properly working radiator.
    There also used to be an old radiator fix called "Rodding them Out" where a radiator shop pulls one of the tanks off and runs a wire down through each of the cores to get the lime deposits out. Then they resolder the tank back in again.
  4. Joey4speed
    Joey4speed FABO Gold Member FABO Gold Member
    681
    467
    Jul 17, 2018
    Jersey
    Local Time:
    10:30 PM
    Hmm. Radiator tubes look clean except for that loose debris. Looks a bit too cylindrical to be scale.
    Is it possible that "oil absorbent" like kitty litter granuals somehow found their way into the cooling system ports? Maybe from an overzealous person pouring it everywhere around an opened engine or on auto trans fluid while the radiator cap was off?
  5. Velocity111
    111
    22
    Jan 16, 2017
    New York
    Local Time:
    10:30 PM
    72’ Dart with a brand new FHO 572” Hemi. Electrical pusher fan with no shroud. The main heating issues was an improperly assembled pedal assy, which sometimes let the brakes stay engaged so the extra work drove heat. I didn’t taste it. I just know this stuff ain’t supposed to be there...
  6. Velocity111
    111
    22
    Jan 16, 2017
    New York
    Local Time:
    10:30 PM
    im running an alum radiator,heads, block, etc. so will likely not do the vinegar. Radiator is out and flushed the way you mentioned, my photo was taken after multiple flushes!!...doh!
  7. Velocity111
    111
    22
    Jan 16, 2017
    New York
    Local Time:
    10:30 PM
    anything is possible, but don’t know how they would have got there,and not sure they would disintegrate when rubbed.
  8. Kendog 170
    Kendog 170 Let the boy go !
    977
    602
    Mar 10, 2016
    Tewksbury Ma.
    Local Time:
    10:30 PM
    So pusher fan and mechanical fan on engine no shroud ? I think no shoud is a big issue. JMO Any pics of fans and radiator?
    After flushing did you get at least one peice to examine ?
  9. Kendog 170
    977
    602
    Mar 10, 2016
    Tewksbury Ma.
    Local Time:
    10:30 PM
    I drove my 500 Stroker for a season running real warm. Checked into everthing but T-stat. Well wouldn't you know the t-stat wasn't opening fully.
  10. Mopar44134
    Mopar44134 Well-Known Member
    243
    44
    Jul 20, 2011
    Ohio
    Local Time:
    10:30 PM
    looks like sand to me. didnt they use to use sand in the engine block mold process?
    • Like Like x 1
    • George Jets
      2,135
      3139
      Jan 18, 2019
      Farmington MN
      Local Time:
      9:30 PM
      Radiator Shops have Ultrasonic Cleaning Tanks.
      Can take the radiator to them, that should break up those small particles so you can rinse it out clean.
      • Like Like x 1
      • famous bob
        famous bob mopar misfit FABO Gold Member
        16,614
        6389
        Aug 14, 2011
        okla
        Local Time:
        9:30 PM
        I had the same thing, not as bad and would circulate thru the tubes , And no way in hell I`d taste it .
        Mine seemed to accumulate at the rad cap, ,and I would wipe them out w/ a rag every time I`d check the rad. .
        Thinking it was stop leak / antifreeze/water wetter -stuff, I shimmed my rad cap gaskets to beef it up and havent noticed any lately---------??
        Your front pusher may be blocking air flow ,wondering if mine does ------------
      • Kendog 170
        977
        602
        Mar 10, 2016
        Tewksbury Ma.
        Local Time:
        10:30 PM
        I have a pusher and mechanical with shroud. Pusher is set up with T-stat to only come on at 200' if I'm stuck in traffic.
        • Like Like x 1
        • fklskv
          fklskv Well-Known Member
          1,135
          591
          Aug 14, 2011
          Lackawanna, NY
          Local Time:
          10:30 PM
          • Like Like x 1
          • 72bluNblu
            72bluNblu FABO Gold Member FABO Gold Member
            10,672
            5106
            Nov 28, 2008
            NorCal
            Local Time:
            7:30 PM
            DO NOT TASTE IT. Good god people are dumb.
            It looks like one of those desiccant pouches broke. You know, those little pouches that say “do not eat” that you get in various different shipping boxes, beef jerky, etc. They’re there to absorb moisture. Most are a silica granule of some kind.
            As for how to get them out, man, that’s tough. It’ll probably need to go to the radiator shop. And you’ll have to flush the heck out of the block too.
          • Dana67Dart
            4,348
            2649
            Jul 16, 2017
            Northern Colorado
            Local Time:
            8:30 PM
            No, not dumb.... I don't mean sprinkel it on your corn flakes, I mean touch it to your tongue, if it tastes salty, sweet, tart, etc it helps guide you as to what it is and how to get rid of it.
            My money is that it is calcium / lime scale (crumbles when pinched between fingers, I bet it has a salty taste, and would desolve readily in vinegar)
          • Velocity111
            111
            22
            Jan 16, 2017
            New York
            Local Time:
            10:30 PM
            Just a pusher fan. There is not enough room between the water pump and radiator to put anything. I had a number of these pieces get flushed out, and again best description i can give is it's wet dishwashing detergent.
          • Velocity111
            111
            22
            Jan 16, 2017
            New York
            Local Time:
            10:30 PM
            I pulled the stat and boiled it on the stove and confirmed its' a 160 stat that opens at 170-175. ran it for a day with no stat, but a buddy who I trust is going to load a disk in there to slow the churn but nothing mechanical to slow things down too much.
          • Velocity111
            111
            22
            Jan 16, 2017
            New York
            Local Time:
            10:30 PM
            Could very well be stop leak, and the pusher could be hurting more than helping, the real test will be when I get the radiator cleaned out. In truth i think a big part fo the issue was solved with the brakes, as before i pulled the radiator I drove it and it never got above 175 - so i'm happy with that. Once the radiator is cleaned out, it'll only run better hopefully.
          • Velocity111
            111
            22
            Jan 16, 2017
            New York
            Local Time:
            10:30 PM
            Initially I thought these particles might have been these silica balls, but silica does not soften in liquid, and my particles will disintegrate in your fingers...
          • Velocity111
            111
            22
            Jan 16, 2017
            New York
            Local Time:
            10:30 PM
            Possibly, but again I don't think lime scale/calsium softens when in liquid - I could be wrong?? I woudl also pass on the vinegar as i'm running an aluminum radiator, heads, block, etc and those two don't mix well.
          • Dana67Dart
            4,348
            2649
            Jul 16, 2017
            Northern Colorado
            Local Time:
            8:30 PM
            My experience with scale is when dry it crumbles, when wet it smears.
            I wasn't suggesting you put vinegar in your engine, I was suggesting putting some of the chunks in a dish and adding vinegar and see if it disolves
          • Car Nut
            Car Nut Mopar Master
            14,335
            61890
            Dec 28, 2018
            Zombieland
            Local Time:
            8:30 PM
            Use one of these.
            • Like Like x 1
            • Velocity111
              111
              22
              Jan 16, 2017
              New York
              Local Time:
              10:30 PM
              If thats the case, then this could very well be scale.
              • Like Like x 1
              • famous bob
                16,614
                6389
                Aug 14, 2011
                okla
                Local Time:
                9:30 PM
                You have an alum. block ??
