Radiator Help
dmann1720
Member
Mass
I have 75 Dart with slant 6. Looking to replace the radiator or have it rebuilt any suggestions to where i can get a new one or send out to be rebuilt thank you
Personally I would stay away from aluminum.
Search "overheating" here on FABO and see what they have in common.
Not saying there is anything inherently wrong with AL radiators, but!
I was gonna say today's the day! But then I re read your post and it's a slant 6. Dang it. I have 2 NORS brass radiators in boxes for small blocks
Rebuilt? Do you know if it needs a new core or one of the tanks are damaged?
Yes Glen Ray is the specialist, but '75 a square top and so if you can find a local shop, they should be able to recore.
You need to consider the following...
Core tube spacing
Core tube size
Number of core rows
Fin count fins per inch.
Us radiator has a great video on the subject.
Where in mass are you? If you are near 395 (290) area there is a great radiator shop in Plainfield CT called BGR radiator in the Plainfield industrial park. Ask for Steve.
If you know where the Mass pike meets up with the 290/395 exchange… they are about 25mins south of there.
Syleng1
Syleng1
I live in Freetown so plainfield CT is about a hour half ride for me.
Top tank is fine the bottom tank i think where the leak is coming from. the fins are rotten out pretty bad.
