will an early a body radiator fit in a 68 a body car. both are for a v8.
the 68 has the original water pump...i know theyre differentIt should. I think they are the same dimensions and bolt pattern but the 69 and older use the cast iron water pump. Are you running a 70-up water pump or earlier?
